[mapguide-users] Writing in "about" widget
Daniel Alonso Parra
danialonsop at yahoo.es
Fri May 17 03:46:24 PDT 2019
I checked like every file before asking except that It seems, now it worked so easy, you are awesome, thank you so much!
En viernes, 17 de mayo de 2019 12:28:33 CEST, Jackie Ng <jumpinjackie at gmail.com> escribió:
Okay, this is what you do. I assume you know how to make/edit a HTML web
page.
The about widget by default refers to a relative URL of:
widgets/About/About.html
This translates to a physical path of:
Windows: C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\widgets\About\About.html
Linux:
/usr/local/mapguideopensource-3.1.2/webserverextensions/www/fusion/widgets/About/About.html
... assuming you are using the latest stable release (3.1.2) and installed
into the default location.
This is the file you want to edit with your own content.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20190517/d9a0a83f/attachment.html>
