[mapguide-users] XYZ maps not listed in "external providers"
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed May 29 04:45:53 PDT 2019
I'm not sure I did exactly what you meant, but when I remove the other child maps and only have the XYZ, I get the same Fusion error as I do when I move it up in the list with the other maps.
What I did was delete the stuff scratched out here:
[cid:06b3e652-b9e5-4bcb-af8a-7bf5d681e243]
[GEMTEC]<https://www.gemtec.ca/>
Andrew DeMerchant
Fredericton, NB
tel: 506.453.1025 x163 / toll-free: 1.877.243.6832
mobile: 506.470.2007 / fax: 506.453.9470
From: mapguide-users <mapguide-users-bounces at lists.osgeo.org> on behalf of GordonL <gordon.luckett at arrowgeomatics.com>
Sent: Tuesday, May 28, 2019 4:19 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] XYZ maps not listed in "external providers"
Open MapGuide Maestro.
Open your Application/Flexible Web Layout
Edit as XML
remove the <Extensions> and then try with the XYZ layers only...
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20190529/6fc1c419/attachment.html>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20190529/6fc1c419/attachment.png>
