[mapguide-users] Show MapGuide Map using OpenLayers
frieda
ruslankutowoj at web.de
Mon Nov 18 08:15:56 PST 2019
Hello,
I'm trying to display a MapGuide Map using OpenLayer v6.1.0. I can see the
Map in preview in Maestro but the Map does not showing up in OpenLayers, the
example from here works fine:
https://openlayers.org/en/latest/examples/mapguide-untiled.html
I don't understand the Version parameter, which is set to 3.0.0 in the
example code. Is this the MapGuide Version? I'm using MapGuide 2.5.2
This is my code so far:
var agentUrl = 'http://192.168.128.176:85/mapguide/mapagent/mapagent.fcgi?';
var mdf = 'Library://Test/Maps/Test.MapDefinition';
var mapguide = new ol.source.ImageMapGuide({
projection: 'EPSG:31467',
url: agentUrl,
useOverlay: false,
metersPerUnit: 1.00000000000000,
params: {
MAPDEFINITION: mdf,
FORMAT: 'PNG',
VERSION: '2.5.2',
USERNAME: 'Administrator',
PASSWORD: 'admin'
ratio: 1
var layersource = new ol.layer.Image({
source: mapguide
var map = new ol.Map({
layers: [layersource],
target: 'map',
view: new ol.View({
zoom: 12,
center: [3474969.4459683, 5494505.61502864]
There are no errors, just a white screen with zoom control.
This is the information I obtained from maestro for that test map:
*PROJCS["DHDN/3.Gauss3d-3",GEOGCS["DHDN/3.LL",DATUM["DHDN/3",SPHEROID["BESSEL",6377397.155,299.15281535],TOWGS84[598.1000,73.7000,418.2000,-0.202000,-0.045000,2.455000,6.70000000]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",3500000.000],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",1.000000000000],PARAMETER["central_meridian",9.00000000000000],PARAMETER["latitude_of_origin",0.00000000000000],UNIT["Meter",1.00000000000000]]*
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
