[mapguide-users] MapGuide Open Source 4.0 Preview 1.1 available
Jackie Ng
jumpinjackie at gmail.com
Tue Sep 3 03:26:39 PDT 2019
Hi All,
I've put up a new 1.1 preview release of MapGuide Open Source 4.0
https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Preview1.1/Notes
When I announced preview 1, I discovered shortly afterwards a bug in the new
QUERYMAPFEATURES mapagent api that breaks viewer interaction with
mapguide-react-layout (git master, which will eventually become the next
0.12 release).
This 1.1 preview includes a fix for this new API. If you don't use
mapguide-react-layout (bleeding-edge from git master), you probably won't be
affected by this bug and can stick with the existing preview 1 release.
I'll also be delaying the Linux binaries to Preview 2 as the revised
packaging mechanism I was planning to introduce still has kinks to iron out.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
