[mapguide-users] Reset MapAgent credentials
Jackie Ng jumpinjackie at gmail.com
Thu Sep 26 07:41:11 PDT 2019
Did you run the Setup/InstantSetup.exe tool after extracting the instantsetup
bundle? That sets up all the various config files
(serverconfig.ini/webconfig.ini/etc) so that dictionaries. resource files,
etc are pointing to all the correct paths relative to where you extracted
the instant bundle to.
You need the .net Framework already installed in order to run this tool
(this tool is a .net application)
The fact that you're seeing "..\..\..\Oem\CsMap\CsMapDev\Dictionaries\"
tells me you haven't run this part.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
