[mapguide-users] Custom coordinate system error with Fusion
mcs at gdtest.it
mcs at gdtest.it
Mon Apr 6 12:11:28 PDT 2020
I would like to load in Mapguide some shapefiles that use a custom coordinate
system, based on Lambert and GCS_ETRS_1989.
Everything seems fine up to the creation of a map, I configure my map with
WGS PseudoMercator to use then the map on a Fusion viewer and with google
maps as background.
When I configure the map with this Coordinate system, I can calculate
correctly the map extent (seems mapguide convert without problems from
custom CRS to WGS84).
When I run the fusion layout, in the map no layer is shown and in the
mapguide error log I get this error , it seems that mapguide can not use
correctly my custom CRS.
How can I solve this ?
thanks
<pre>
Fusion Viewer 192.168.32.39 Administrator
Error: The coordinate system initialization failed.
Could not initialize the geodetic transformation.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.1.1\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute() line 125 file
c:\working\build_area\mapguide\3.1.1\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures() line 1093 file
c:\working\build_area\mapguide\3.1.1\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection() line 1823 file
- MgCoordinateSystemFactory.GetTransform() line 221 file
c:\working\build_area\mapguide\3.1.1\x64\mgdev\common\geometry\CoordinateSystem/CoordinateSystemFactory.cpp
- MgCoordinateSystemTransform.SetSourceAndTarget() line 838 file
..\CoordinateSystem\CoordSysTransform.cpp</pre>
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
