[mapguide-users] RenderMap: MgOutOfMemoryException
frieda
ruslankutowoj at web.de
Mon Aug 24 07:59:23 PDT 2020
Hello I'm using MapGuide v.2.5.2.7949 in an ASP.NET Application.
I'm facing an out of memory exception throwed by this function (RenderMap):
http://cmnmaps.ca/mapguide/help/webapi/de/dbd/class_mg_rendering_service_a7767628fe456bfd90e9010a19ed83e04.htm#a7767628fe456bfd90e9010a19ed83e04
In my App I'm trying to print the map to a PNG format and if I set 600 DPI I
get the exception. What's wrong here? If I set lower DPI, like 300 it works
fine.
My Code:
<CLSCompliant(False)> Public Sub InitializeMapImage(ByRef pr_objMapGuide As
MapGuide, ByVal pv_Plotbox As MgEnvelope,
ByVal pv_dblPageWidth As Double,
ByVal pv_dblPageHeight As Double, Optional ByVal pv_strFormat As String =
"PNG")
Try
Dim Map As MgMap = pr_objMapGuide.Map
Dim selection As New MgSelection()
selection.Save(pr_objMapGuide.ResourceService, Map.Name)
selection.Open(pr_objMapGuide.ResourceService, Map.Name)
Dim SelXML As String = selection.ToXml
Dim white As New MgColor(255, 255, 255)
Dim pxMapWidth As Double = (pv_dblPageWidth / inch) * DPI
Dim pxMapHeight As Double = (pv_dblPageHeight / inch) * DPI
Dim byteReader As MgByteReader =
pr_objMapGuide.RenderingService.RenderMap(Map, selection, pv_Plotbox,
pxMapWidth, pxMapHeight, white, "PNG")
Dim memBuff As New IO.MemoryStream
Dim byteBuffer(1024 ^ 2) As Byte
Dim intBytes As Integer = byteReader.Read(byteBuffer, 1024 ^ 2)
While intBytes > 0
memBuff.Write(byteBuffer, 0, intBytes)
intBytes = byteReader.Read(byteBuffer, 1024 ^ 2)
End While
Dim BitMap As New Drawing.Bitmap(memBuff)
BitMap.SetResolution(Convert.ToSingle(DPI),
Convert.ToSingle(DPI))
Dim imgMap As Image = BitMap
m_Map = imgMap
Catch exRange As MgOutOfRangeException
Throw New Exception("", exRange)
Catch exMemory As MgOutOfMemoryException
Throw New Exception("", exMemory)
Catch ex As Exception
Throw New Exception("", ex)
End Try
End Sub
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
