[mapguide-users] hiding fusion parameters applicationdefinition
Jackie Ng jumpinjackie at gmail.com
Mon Dec 7 22:15:05 PST 2020
I'm pretty sure if you omit the ApplicationDefinition query string parameter,
it will fall back to reading from a file named ApplicationDefinition.xml in
the same directory as the template index.html.
So just save a copy of your appdef as that file name in your template
directory and you should be good to go.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
