[mapguide-users] How do I set the right projection in OL for OSM?
Jackie Ng
jumpinjackie at gmail.com
Wed Jan 29 02:28:30 PST 2020
If you changed the map projection in Maestro, did the bounding box
coordinates of the Map Definition change as well? If not, you're probably
looking at the 3857 map but looking at it from the starting point of the
un-projected 31467 bounding box view. In this case, you'll have to update
the bounding box of the Map Definition with the projected coordinates as
well.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
