[mapguide-users] problem with selection set - more info
Jackie Ng
jumpinjackie at gmail.com
Thu Jan 30 02:10:06 PST 2020
Ok, here's the background.
Those PHP scripts in question shouldn't be called now because we now have a
version of the QUERYMAPFEATURES mapagent operation that fulfills the needs
that these 3 scripts previously provided.
Fusion.Layer.MapGuide has a flag (bUseNativeServices) that determines
whether we call QUERYMAPFEATURES or the PHP scripts (ref:
https://trac.osgeo.org/fusion/browser/trunk/layers/MapGuide/MapGuide.js#L82)
This flag should be set to true when Fusion does a MG version check on
startup. Any MapGuide version >= 2.6 should be flipping this flag to true.
So the fact that your copy of Fusion is still making requests the old way is
strange. Even the build of Fusion included in MGOS 2.6.1 should be making
requests the new way.
So this raises my main question: Are you using a custom build of Fusion and
not the one that is bundled with your new MGOS 3.1.2 install? Fusion should
not be calling these 3 PHP scripts anymore.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
