[mapguide-users] Troubleshooting Ajax Viewer Windows Server 2016 application migration
tuceda tanguy.uceda at 1spatial.com
Sun Mar 22 22:16:09 PDT 2020
I have an old MG 2.5 application that use Ajax Viewer and works well on a
Windows Server 2008 and 2012.
This application have an aspx page as entry point, that read the library
WebLayout identifier defined in url parameter.  The aspx extract the
MapDefinition, and manipulates a MgMap instance by adding some FDO filters
to map layers. When its done, the aspx redirect to mapviewerajax URL with a
session WebLayout identifier in parameters.
Then i tried to move this application on Windows Server 2016. The map is
displayed well, but all operations applied to MgMap have no effect. Layers
are not filtered. If I set the same filters in LayerDefinitions with
Maestro, this works well.
I tried to move on another Windows 2016 Server without success.
I have no error or any log information.
What i'm doing wrong ?
Thanks in advance
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
