[mapguide-users] mapguide+google earth in IE
RenoSun renolionheart at gmail.com
Sun May 3 19:35:00 PDT 2020
Hi Evan,
It looks really good of your mobile viewer and using mapguide + google earth
in IE. Looks like you customized your Kaliopa Mapguide Mobile Viewer as
well, and it looks nice.
Autodesk Infrastructure Map Server (AIMS) is a dead product now. I won't
recommend you to use it.
https://www.autodesk.com/products/infrastructure-map-server/overview
I will recommend you to use mapgudie 3.1.2 instead of using AIMS. However,
it can be difficult if you are loading data from ArcSDE (ESRI). Also, have
look on both  mapguide-rest <https://github.com/jumpinjackie/mapguide-rest>
and  mapguide-react-layout
<https://github.com/jumpinjackie/mapguide-react-layout>  . They may help you
to make your application more powerful in many ways.
Cheers,
Reno
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
