[mapguide-users] Preview layer created from SQL Server data source
_Jon_
jrizzo at Langan.com
Tue Nov 3 08:36:35 PST 2020
Hello,
I have created a SQL Server data source, defined a feature class, and copied
a bunch of polyline features into it. When I preview the feature source in
Maestro, I can see my feature class listed with the attributes (and key)
that I defined. If I click View Data from the feature source preview, I can
see all of the data associated with the features and if I click View
Feature, I can see those features graphically. however, when I create a
layer from this feature source and define a basic style for the Line
features, the layer (or perhaps just the preview function) does not appear
to work properly. If I try to preview the layer, I get the exception below.
Needless to say, if i try to build a MapDefinition or ApplicationDefintion
using this layer, it also doesn't work. Any idea what could be going wrong
or how to fix it?
Here is the exception:
System.Exception: The remote server returned an error: (559)
MgDbXmlException.: The custom error module does not recognize this error.
---> System.Net.WebException: The remote server returned an error: (559)
MgDbXmlException.
at System.Net.HttpWebRequest.GetResponse()
at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.SetResourceXmlData(String
resourceId, Stream content, Stream header) in
C:\projects\mapguide-maestro\OSGeo.MapGuide.MaestroAPI\Http\HttpServerConnection.cs:line
662
--- End of inner exception stack trace ---
at
Maestro.Editors.Preview.LocalMapPreviewer.<>c__DisplayClass10_0.<Preview>b__1(Object
obj, Exception ex) in
C:\projects\mapguide-maestro\Maestro.Editors\Preview\LocalMapPreviewer.cs:line
166
at Maestro.Shared.UI.BusyWaitDialog.Run(String message, BusyWaitDelegate
action, Action`2 onComplete, Boolean bPreserveThreadCulture) in
C:\projects\mapguide-maestro\Maestro.Shared.UI\BusyWaitDialog.cs:line 103
at Maestro.Editors.Preview.LocalMapPreviewer.Preview(IResource res,
IEditorService edSvc, String locale) in
163
at Maestro.Base.Editor.EditorContentBase.Preview() in
C:\projects\mapguide-maestro\Maestro.Base\Editor\EditorContentBase.cs:line
357
at Maestro.Base.Commands.PreviewResourceCommand.Run() in
C:\projects\mapguide-maestro\Maestro.Base\Commands\PreviewResourceCommand.cs:line
42
at ICSharpCode.Core.WinForms.ToolBarCommand.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
