[mapguide-users] memory leak: IGWSQueryDefinition and FdoFilter
artem
artimoshagaming at gmail.com
Thu Sep 17 03:03:15 PDT 2020
About memory leaks in SHP provider, there was same problem with GetFilter(),
FDO\Providers\SHP\Src\Provider\ShpImpExtendedSelect.cpp
in function
ShpIScrollableFeatureReader* ShpImpExtendedSelect::ExecuteScrollable()
it is invoked there several times without FdoPtr<>.
I also have found another one memory leak in SHP provider (probably better
to post it on FDO forum, but as continue of my words)...
It is caused by:
in function
by next alloc:
propStubs[0].m_name = new wchar_t[wcslen(L"FeatId")+1];
It should be cleared in
ShpScrollableFeatureReader::~ShpScrollableFeatureReader()
but it is not, because in my case m_NumProps == 0 (0 - as input parameter to
ShpScrollableFeatureReader constructor "m_orderingProperties->GetCount()")
but I'm not sure how to fix that case correctly.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
