[mapguide-users] Does mapguide support rasters stored in Postgis
Jackie Ng jumpinjackie at gmail.com
Mon Aug 16 07:35:33 PDT 2021
Okay, I took a look at why the GDAL provider returned true (because this
was easier than trying to figure out how to load some rasters into postgis)
Turns out the GDAL provider automatically sets connection state to open
regardless of the data source string you specify in the connection
parameters. This has an effect on the MapGuide side of making every GDAL
connection test be a successful result, hence explaining why even a
gibberish string will return a TRUE result.
That particular bug is being tracked here:
https://trac.osgeo.org/fdo/ticket/995
All I can say at this point is try to proceed as though the PGSQL
connection string you passed in is legit and see how things go.
- Jackie
You wrote:
Thanks again Jackie, much appreciated your support.
I’ve realized that regardless of what you write on the FILE path… the TEST
result is always TRUE
I wrote Gibberish (literally) and still TRUE
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210817/5664aa3f/attachment.html>
