[mapguide-users] React Layout - set layer visibility
Jackie Ng
jumpinjackie at gmail.com
Tue Jul 6 03:44:08 PDT 2021
Assuming you are using the latest 0.13.x release, please try the 0.13.3
release I just published today
https://github.com/jumpinjackie/mapguide-react-layout/releases/tag/v0.13.3
This release has fixes for inconsistent layer/group visibility on refresh
after doing layer/group changes server-side (which sounds like the problem
you're having)
- Jackie
You wrote:
Hi, how can I programmatically change the visibility of a layer?
I modified and saved the map on server side but the viewer allways sends
"hidelayers= layerid" in the request.
Is it possible top change the visibility on the client side?
Thanks svlad
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210706/f33a12c5/attachment.html>
