[mapguide-users] R: R: MapGuide WFS uniqueID
gvtomm gvtomm at gmail.com
Sat Nov 20 04:56:19 PST 2021
Yes Jackie, this resolve my issue!
In the same MGOS installation, if the feature source id change, also the nsXXXXXXX ID change.
But the most important thing is that, in case of migration from one MGOS to a new MGOS, if all data sources will have the same resource id (i.e. the same path and name) they will have also the same nsXXXXXXX calculated from hash.
I hope we don't find any bugs :)
Thank you very much
gvtomm
Da: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Per conto di Jackie Ng
Inviato: venerdì 19 novembre 2021 09:10
A: mapguide-users at lists.osgeo.org
Oggetto: Re: [mapguide-users] R: MapGuide WFS uniqueID
I took a peek at how the nsXXXXXXX is being generated in the Web Tier code.
The number is a hash of the feature source id (Library://....FeatureSource) and should be the same hash on any server as long as the feature source id is the same. If the same feature source id produces different hashes on different servers, it is probably a bug.
- Jackie
You wrote:
Hi Mark
Thank you, I tried with MG_CONTROL (very good script!!) and my  polygon
table
Insert into MG_CONTROL
   ( FDO_ORA_OWNER, FDO_ORA_NAME, FDO_ORA_GEOMCOLUMN,  FDO_CLASS_NAME,
FDO_SRID,
    FDO_IDENTITY)
Values
   ('ATS_BASE', 'BA_MUNICIPALITY_POLYGON', 'GEOM', 'MY_POLYGON', 82087,
    'FID');
than I Used the Mapagent Web Tier Test page with WFS GETCAPABILITIES to see
the result
 <http://xxx:8018/mapguide/mapagent/index.html> http://xxx:8018/mapguide/mapagent/index.html
When I use Gaia to test the service, the reference name is
ns160697717:MY_POLYGON
Result
In my opinion MG_CONTROL can handle the name of the feature class, but not
the ID before the name that depends from the data source created in MGOS
(I’m trying to force/change the ID)
Do you have experienced something else, please?
Best regards
Gvtomm
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20211120/18be03da/attachment.html>
