[mapguide-users] sqlserver view is no limit row search STSrid ?
周宜和
jyh at mail.gaias.com.tw
Fri Sep 10 18:50:05 PDT 2021
Hi Jackie
sorry about my previous Email
select top 1 GeomColumnName from GeomTableName where GeomColumnName is not null
if the all geom data is null
will cause full table scan, make sqlserver cpu busy again.
Please keep now version SampleColumnSrid is good sample .
Just select top 1 GeomColumnName from GeomTableName
Sent: Saturday, September 11, 2021 9:39 AM
To: 'MapGuide Users Mail List' <mapguide-users at lists.osgeo.org>
Subject: RE: [mapguide-users] sqlserver view is no limit row search STSrid ?
Hi Jackie
I try sqlserverProvider is work find. Thanks for great work.
I still have some question,source code url
https://trac.osgeo.org/fdo/browser/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/ColumnGeom.cpp#L100
https://trac.osgeo.org/fdo/browser/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/Owner.cpp#L429
If first row is null data
mSRID = owner->SampleColumnSrid( GetParent()->GetName(), GetName() );
mSRID will get -1
then next time into FdoSmPhSqsColumnGeom::GetSRID(),the mSRID is -1 will select top 1 then return -1 to mSRID,again and again.
How about select top 1 GeomColumnName from GeomTableName where GeomColumnName is not null
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gordon Luckett
Sent: Friday, September 10, 2021 6:22 PM
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org> >
Subject: Re: [mapguide-users] sqlserver view is no limit row search STSrid ?
Hi Jackie,
I just wanted to confirm that the build works great and the speed at getting the STSrid in SQL Server is very fast now.
On Thu, Sep 9, 2021 at 11:12 AM Jackie Ng <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com> > wrote:
Please try the following patched SQL Server provider
https://download.osgeo.org/mapguide/patches/SQLServerProvider_Ticket996_FDO4.1/SQLServerProvider_Ticket996.zip
Extract and overwrite your copy in your MGOS 3.1.2 install
- Jackie
You wrote:
thanks for open active ticket
<https://trac.osgeo.org/fdo/ticket/996> https://trac.osgeo.org/fdo/ticket/996
I found mysql is fix by Jan 7, 2020
<https://trac.osgeo.org/fdo/ticket/893#comment:5> https://trac.osgeo.org/fdo/ticket/893#comment:5
<https://trac.osgeo.org/fdo/attachment/ticket/893/LimitOneSrid.patch> https://trac.osgeo.org/fdo/attachment/ticket/893/LimitOneSrid.patch
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists.
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210911/27907bfa/attachment.html>
