[mapguide-users] An error occurred during startup - "Failed to Fetch"
Jackie Ng
jumpinjackie at gmail.com
Fri Aug 5 12:39:54 PDT 2022
Assuming you are referring to the mapguide-react-layout viewer (that sounds
a lot like an error message this viewer will throw), then the best course
of action is to open your browser developer tools (general shortcut key is
F12) and look for failed requests in the network tab.
Given this is a fetch error during startup, I suspect it must be a failure
in one of the requests to:
- Fetch the WebLayout or ApplicationDefiniton resource
- Create the runtime map from the Map Definition from the WebLayout or
ApplicationDefinition fetched above.
But looking at the failed requests in the network tab in the browser dev
tools will give the definitive answer on what is the failing request.
Hope that helps.
- Jackie
You wrote:
Are users are receiving a "An error occurred during startup - Failed to
Fetch" error when opening the mapguide viewer in a web browser. Anyone
know what this cause of this error would be? or what log files may shed
some light on it?
Thanks.
*Shane Martin*
Manager of Information Technology
Town Of Ingersoll
519-485-0120 ext. 6264
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220806/e1f54a67/attachment.htm>
