[mapguide-users] REACT Sample
pierre.cardinal at sympatico.ca
Fri Aug 26 13:58:31 PDT 2022
* Also the GETLAYERKML and GETLAYERKML operations seam problematic.
Also the GETLAYERKML and GETFEATURESKML operations seam problematic.
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de pierre.cardinal at sympatico.ca
Envoyé : 26 août 2022 16:56
À : 'MapGuide Users Mail List' <mapguide-users at lists.osgeo.org>; 'Jackie Ng' <jumpinjackie at gmail.com>
Objet : Re: [mapguide-users] REACT Sample
Hi Jackie,
The cause of the problem is with the operation GETMAPKML.
Request sent by MapAgent
http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPKML <http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPKML&VERSION=1.0.0&CLIENTAGENT=MapGuide+Developer&FORMAT=KML&DPI=96&MAPDEFINITION=Library%3A%2F%2FSamples%2FSheboygan%2FMaps%2FSheboygan.MapDefinition> &VERSION=1.0.0&CLIENTAGENT=MapGuide+Developer&FORMAT=KML&DPI=96&MAPDEFINITION=Library%3A%2F%2FSamples%2FSheboygan%2FMaps%2FSheboygan.MapDefinition
or
Request sent by application Sample
http://localhost/mapguide/mapagent/mapagent.fcgi?USERNAME=Anonymous <http://localhost/mapguide/mapagent/mapagent.fcgi?USERNAME=Anonymous&OPERATION=GetMapKml&VERSION=1.0.0&MAPDEFINITION=Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition> &OPERATION=GetMapKml&VERSION=1.0.0&MAPDEFINITION=Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
With MGOS 3.1.2, MGOS build 9862 (4P3) and MGOS 4P4, it is impossible to use the operation GETMAPKML. I did some tests with the MapAgent Test Pages and I always have the same result. The operation returns a pop up window to download the file mapagent.fcgi (except for XML format).
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org> > De la part de pierre.cardinal pierre.cardinal
Envoyé : 25 août 2022 12:20
À : Jackie Ng <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com> >; mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
Objet : [mapguide-users] Ré: Re: REACT Sample
Hi Jackie,
Thank you for your prompt answer
For cases 2 and 3 (MGOS 4.0 P3 and IIS under Server 2012 R2, MGOS 4.0 P4 and IIS under Win10)
I was already using the "resource" parameter.
For case 1 (MGOS (build 9862) and IIS under Win10)
I changed the parameter "ApplicationDefinition" for "resource", now I have the same result as in the two other cases. When I click on « View as KML », the function returns a pop up window to download the file mapagent.fcgi.
Pierre
------ Message d’origine ------
De: jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>
À: mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
Envoyé: jeudi 25 août 2022 09:09
Objet: Re: [mapguide-users] REACT Sample
Use "resource" instead of "ApplicationDefinition" as the query string parameter.
- Jackie
You wrote:
With MGOS (build 9862) and IIS under Win10.
I have no problem to display the REACT viewer when I am using the viewer directory (ziewer.zip or yarn install from the source) .
But when I am trying to display the REACT viewer with the sample directory, http://localhost/mapguide/sample/sample_template.html?ApplicationDefinition=Library://Samples/Sheboygan/FlexibleLayouts/React.ApplicationDefinition <http://localhost/mapguide/sample/sample_template.html?ApplicationDefinition=Library://Samples/Sheboygan/FlexibleLayouts/React.ApplicationDefinition&locale=en> &locale=en
Note : I have a React flexible layout (react.xml) in FlexibleLayouts of the Sheboygan package
I have the following message :
An error occurred during startup
No resource parameter found. This viewer assumes this parameter to be set in the query string and must refer to a valid Web Layout or Application Definition. If not specified, it will try to init from a Application Definition document at appdef.json
With MGOS 4.0 P3 and IIS under Server 2012 R2
Also I have no problem with the viewer directory but, when I am trying to display the REACT viewer with the sample directory, mostly everything is OK except the « View as KML » function. When I click on « View as KML », the function returns a pop up window to download the file mapagent.fcgi.
With MGOS 4.0 P4 and IIS under Win10.
Regards,
Pierre
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists.
_____
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220826/efa0f63f/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220826/efa0f63f/attachment.png>
