[mapguide-users] WFS Select Within MGOS 3.1.2
Jackie Ng jumpinjackie at gmail.com
Wed May 11 05:31:17 PDT 2022
Hi Gordon,
A 413 error is most likely being thrown at the IIS/Apache web server level.
I know IIS has things like 30MB payload limits for POST requests. There's
probably a similar restriction on URL length.
Failing that, try using POST instead of GET for the WFS select within if
it's possible as for POST all request parameters will be in the submitted
body and not specified in the URL.
- Jackie
You wrote:
Hi All,
has anyone had any success with "select-within" selecting WFS generated
layers?
Currently getting a '413 Request entity too large: request URL path too
large' with only my layers coming from WFS.
Trying to figure out if it's a bug or my setup.
thanks
gordon
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220511/54922523/attachment.htm>
