[mapguide-users] WFS Select Within MGOS 3.1.2
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Fri May 20 02:59:33 PDT 2022
Yes, it's one mapguide server with an FDO connection to another mapguide
server with WFS.
I will try to sniff out the request.
On Fri., May 20, 2022, 5:26 a.m. Jackie Ng, <jumpinjackie at gmail.com> wrote:
> I may have interpreted your original email wrong.
> Are you getting a 413 from a MapGuide-hosted WFS layer (ie. A feature
> source with WFS publishing metadata applied), or is the 413 coming from a
> feature query to a feature source that uses the WFS FDO provider (ie.
> MapGuide *is not* the WFS server)?
> Because if it's the latter (a feature source using the WFS FDO provider)
> then the 413 error looks like a problem from the WFS service you're
> contacting and that's beyond our control at that point.
> My original reply assumed the former, but the stack trace you posted
> assumes the latter.
> If it is indeed the latter, perhaps hook up fiddler or any other HTTP
> traffic interception software and see what the actual WFS requests being
> made are that is triggering a HTTP 413 response.
> - Jackie
> You wrote:
> Thanks Jackie,
> Yes, both the WFS (MapGuide) server's IIS is set to max sizes for Request
> parameters and POST/GET requests.
> The Select Within in Fusion calls:
> GetParent().Fusion.xml2json(callback, r);
> which causes the error
> *Exception: An exception occurred in FDO component. Error occurred in
> Feature Source (Library://WFS/SANDBOX_WFS.FeatureSource): Unexpected error
> encountered while accessing the server. (Cause: The requested URL returned
> error: '413 Request entity too large: request URL path too large'. , Root
> Cause: The requested URL returned error: '413 Request entity too large:
> request URL path too large'. ) -
> MgRenderingServiceHandler.ProcessOperation() line 83 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
> - MgOpQueryFeatures.Execute() line 125 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
> - MgServerRenderingService.QueryFeatures() line 1093 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
> - MgServerRenderingService.RenderForSelection() line 1823 file
> - MgServerFeatureService.SelectFeatures() line 451 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
> - MgServerSelectFeatures.SelectFeatures() line 331 file
> c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\feature\ServerSelectFeatures.cpp*
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220520/3d25d235/attachment.htm>
