[mapguide-users] RES: Some questions about mapguide feature source GDAL Provider
liglio.pessoal at nexxa.com.br liglio.pessoal at nexxa.com.br
Sat Oct 1 07:30:10 PDT 2022
Hi Pierre,
1 – It is possible to use file location as a url, or the file must be local
I mean an url like
“https://estatico-redemet.decea.mil.br/radar/2022/09/25/mi/maxcappi/maps/202
2-09-25--18:46:27.png". I tried, and I don´t think it is possible.
2 – It is possible to use multiple files at once ?
In my case , it is not a tiled map, but I can use multiple files. It worked.
3 – If using multiple files, which value to set the bounding box element in
config.xml ?
Yes, each file should use its own world file.
Thanks,
Liglio
De: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Em nome de
pierre.cardinal at sympatico.ca
Enviada em: sexta-feira, 30 de setembro de 2022 12:35
Para: 'MapGuide Users Mail List' <mapguide-users at lists.osgeo.org>
Assunto: Re: [mapguide-users] Some questions about mapguide feature source
GDAL Provider
Hi Liglio,
According to my understanding
For an external file server, you can use alias.
 <https://trac.osgeo.org/mapguide/wiki/ConfiguringAliases>
Put the multiple files in a directory if they représented a tiled map
config.xml ?
Each file should use its own word file.
Regards,
Pierre
2nd invoice (problem with email and mailman)
De : mapguide-users < <mailto:mapguide-users-bounces at lists.osgeo.org>
mapguide-users-bounces at lists.osgeo.org> De la part de
<mailto:liglio.pessoal at nexxa.com.br> liglio.pessoal at nexxa.com.br
Envoyé : 29 septembre 2022 17:29
À :  <mailto:mapguide-users at lists.osgeo.org> mapguide-users at lists.osgeo.org
Objet : [mapguide-users] Some questions about mapguide feature source GDAL
Provider
Some questions about mapguide feature source GDAL Provider:
config.xml ?
  <gml:validArea>
      <gml:boundingBox>
        <gml:pos>-58.4495200765 -34.571399068</gml:pos>
        <gml:pos>-38.8132978305 -12.41568038</gml:pos>
      </gml:boundingBox>
    </gml:validArea>
Thanks,
Liglio
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221001/f9a68e70/attachment.htm>
