[mapguide-users] fusion error in google chrome
pierre.cardinal at sympatico.ca pierre.cardinal at sympatico.ca
Sun Oct 16 13:50:01 PDT 2022
I also have the error in Chrome but it’s still possible to display Google map and Street view  (for Street view, I add my API key in the file ..\Web\www\fusion\widgets\GoogleStreetViewerGoogleStreetView.templ)
Regards,
Pierre
From: mapguide-users <mapguide-users-bounces at lists.osgeo.org> On Behalf Of Gordon Luckett
Sent: Sunday, October 16, 2022 1:57 PM
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Subject: Re: [mapguide-users] fusion error in google chrome
Yes, I still haven't figured out what changed in the Google api that broke MapGuide fusion 3.1.2.
I've been using xyz and skipping the streetview widget lately.
On Wed., Oct. 5, 2022, 10:13 p.m. Hadis Alinia, <hadissaalinia at gmail.com <mailto:hadissaalinia at gmail.com> > wrote:
Thank you, Gordon. The site loads in Google Chrome with the Generic XYZ layer but with adding any of the Google Base maps I get the same error!
I need to use google street view and it doesn't work without the google base map. �
Hadis
On Wed, Oct 5, 2022 at 5:27 PM Gordon Luckett <gordon.luckett at arrowgeomatics.com <mailto:gordon.luckett at arrowgeomatics.com> > wrote:
It is just a XYZ Generic Layer in your layout.
On Wed, Oct 5, 2022 at 5:23 PM Hadis Alinia <hadissaalinia at gmail.com <mailto:hadissaalinia at gmail.com> > wrote:
Hi Gordon, �
Thank you for your prompt reply. Can you specify where I need to change the links to the xyz version? I am adding the commercial maps in Mapguide Maestro under child maps with the google API I have. �
I have the following scripts in my application definition XML :
" <OpenStreetMapScript>http://www.openstreetmap.org/openlayers/OpenStreetMap.js</OpenStreetMapScript>
 �  � <GoogleScript>https://maps.googleapis.com/maps/api/js?key=API KEY</GoogleScript>"
or do you �mean I change the �http://www.google.com links in �fusionSF-compressed.js to �https://mt0.google.com/vt/lyrs=m <https://mt0.google.com/vt/lyrs=m&hl=en&x=$%7Bx%7D&y=$%7By%7D&z=$%7Bz%7D> &hl=en&x=${x}&y=${y}&z=${z}?
Thank you �
Hadis
On Wed, Oct 5, 2022 at 3:19 PM Gordon Luckett <gordon.luckett at arrowgeomatics.com <mailto:gordon.luckett at arrowgeomatics.com> > wrote:
Something has recently changed in the past month or so with the Google API.
I have changed all my links to Google to use the XYZ version:
https://mt0.google.com/vt/lyrs=m <https://mt0.google.com/vt/lyrs=m&hl=en&x=$%7Bx%7D&y=$%7By%7D&z=$%7Bz%7D> &hl=en&x=${x}&y=${y}&z=${z} �
You should still have an API Key (or at least pay for the licence) as it is required by the TOS �
On Wed, Oct 5, 2022 at 2:04 PM Hadis Alinia <hadissaalinia at gmail.com <mailto:hadissaalinia at gmail.com> > wrote:
Hi, �
I am using MapGuide version 3.1.2 and when I add the commercial layers my application �doesn't open in google chrome but works fine with other browsers like Microsoft Edge. When I try to open it in Google Chrome, I get the following errors "Cannot read properties of undefined (reading 'width')
Stack Trace:
 �- ? at � /mapguide/fusion/lib/fusionSF-compressed.js (line: 55)" �
I even changed �fusionSF-compressed.js to �fusionSF.js still doesn't work.
The MapGuide version 2 was working with commercial layers. �
What is the reason and what changes �need to be made?
Thank you �
Hadis
mapguide-users mailing list
mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221016/59047730/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20221016/59047730/attachment.png>
