[mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
pierre.cardinal at sympatico.ca pierre.cardinal at sympatico.ca
Wed Sep 7 06:47:32 PDT 2022
Give a look  at
https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg20022.html
(4 messages)
Regards,
Pierre
-----Message d'origine-----
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de
mg at maw-gis.de
Envoyé : 7 septembre 2022 05:05
À : mapguide-users at lists.osgeo.org
Objet : [mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
I installed exactly the same version of Mapguide on the new server, the data
was transferred unchanged.
There are problems with TIF images that are integrated using GDAL Feature
Source. This errors are in the log file:
2022-09-07T10:44:48> 	3876	MapGuide Maestro v6.0.0.8244
192.168.5.181	Administrator
  Error: An exception occurred in FDO component.
         Error occurred in Feature Source
(Library://Feucht/Data/Topologie/DOK.FeatureSource): Only MOSAIC(), CLIP()
and RESAMPLE() are supported. (Cause: , Root Cause: Only MOSAIC(), CLIP()
and
RESAMPLE() are supported.)
  StackTrace:
   - MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\mg-2.4-x86\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
   - MgOpSelectFeaturesSpatial.Execute() line 110 file
c:\mg-2.4-x86\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
   - MgServerFeatureService.SelectAggregate() line 570 file
c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerFeatureService.cpp
   - MgServerSelectFeatures.SelectFeatures() line 325 file
c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
<2022-09-07T10:46:50> 	1424	Fusion Viewer	192.168.5.68	xxx
  Error: Failed to stylize layer: DOK
(Library://Feucht/Data/Topologie/DOK.FeatureSource): Fail to get image
information. (Cause: , Root Cause: Fail to get image information.)
  StackTrace:
   - MgMappingUtil.StylizeLayers() line 881 file
c:\mg-2.4-x86\mgdev\server\src\services\mapping\MappingUtil.cpp
Does anyone have an idea what is going wrong here?
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
