[mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
pierre.cardinal at sympatico.ca pierre.cardinal at sympatico.ca
Thu Sep 8 06:16:11 PDT 2022
Perhaps this one
https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg23472.html
Regards,
Pierre
-----Message d'origine-----
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de mg at maw-gis.de
Envoyé : 8 septembre 2022 02:11
À : mapguide-users at lists.osgeo.org
Objet : Re: [mapguide-users] Migrating Mapguide 2.4 from Server2012 to 2019
  I did read this before, but it doesn't help. The Layers were not selectable.
Any other ideas ?
Regards
  Uwe
Am 07.09.2022 um 15:47 schrieb pierre.cardinal at sympatico.ca:
> Hi,
> Give a look  at
> https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg20022.h
> tml
> (4 messages)
> Regards,
> Pierre
> part de mg at maw-gis.de Envoyé : 7 septembre 2022 05:05 À :
> mapguide-users at lists.osgeo.org Objet : [mapguide-users] Migrating
> Hi,
> I installed exactly the same version of Mapguide on the new server,
> the data was transferred unchanged.
> There are problems with TIF images that are integrated using GDAL
> Feature Source. This errors are in the log file:
> 2022-09-07T10:44:48> 	3876	MapGuide Maestro v6.0.0.8244
> 192.168.5.181	Administrator
>    Error: An exception occurred in FDO component.
>           Error occurred in Feature Source
> (Library://Feucht/Data/Topologie/DOK.FeatureSource): Only MOSAIC(),
> CLIP() and RESAMPLE() are supported. (Cause: , Root Cause: Only
> MOSAIC(), CLIP() and
> RESAMPLE() are supported.)
>    StackTrace:
>     - MgFeatureServiceHandler.ProcessOperation() line 83 file
> c:\mg-2.4-x86\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>     - MgOpSelectFeaturesSpatial.Execute() line 110 file
> c:\mg-2.4-x86\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>     - MgServerFeatureService.SelectAggregate() line 570 file
> c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerFeatureService.cpp
>     - MgServerSelectFeatures.SelectFeatures() line 325 file
> c:\mg-2.4-x86\mgdev\server\src\services\feature\ServerSelectFeatures.c
> pp
> <2022-09-07T10:46:50> 	1424	Fusion Viewer	192.168.5.68	xxx
>    Error: Failed to stylize layer: DOK
> (Library://Feucht/Data/Topologie/DOK.FeatureSource): Fail to get image
> information. (Cause: , Root Cause: Fail to get image information.)
>    StackTrace:
>     - MgMappingUtil.StylizeLayers() line 881 file
> c:\mg-2.4-x86\mgdev\server\src\services\mapping\MappingUtil.cpp
> Does anyone have an idea what is going wrong here?
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
