[mapguide-users] Some questions about mapguide feature source GDAL Provider
pierre.cardinal at sympatico.ca pierre.cardinal at sympatico.ca
Fri Sep 30 08:35:25 PDT 2022
Hi Liglio,
According to my understanding
1 – It is possible to use file location as a url, or the file must be local
For an external file server, you can use alias.
https://trac.osgeo.org/mapguide/wiki/ConfiguringAliases
2 – It is possible to use multiple files at once ?
Put the multiple files in a directory if they représented a tiled map
3 – If using multiple files, which value to set the bounding box element in
config.xml ?
Each file should use its own word file.
Regards,
Pierre
2nd invoice (problem with email and mailman)
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de
liglio.pessoal at nexxa.com.br
Envoyé : 29 septembre 2022 17:29
À : mapguide-users at lists.osgeo.org
Objet : [mapguide-users] Some questions about mapguide feature source GDAL
Provider
Some questions about mapguide feature source GDAL Provider:
config.xml ?
  <gml:validArea>
      <gml:boundingBox>
        <gml:pos>-58.4495200765 -34.571399068</gml:pos>
        <gml:pos>-38.8132978305 -12.41568038</gml:pos>
      </gml:boundingBox>
    </gml:validArea>
Thanks,
Liglio
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220930/5605c7bb/attachment.htm>
