[mapguide-users] MapGuide 4.0 Beta 1
Patrik Johansson mapguide at morkl.se
Fri Apr 7 03:25:58 PDT 2023
Two of the Fusion php scripts also fail because of get_magic_quotes_gpc:
* Web\www\fusion\layers\MapGuide\php\GetSelectionProperties.php
* Web\www\fusion\layers\MapGuide\php\SaveSelection.php
The attached patch removes the call from both of them.
Best regards,
Patrik Johansson
On Thu, Apr 6, 2023 at 5:15 PM Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi Dan,
> Thanks for the heads up.
> A fixed version of serverdatafunctions.php is available in the
> post-release section of the 4.0 Beta 1 release notes.
> https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Beta1/Notes#Post-releasepatches
> - Jackie
> You wrote:
> Hi!
> I have just installed MapGuide OpenSource on my virtual machine (Windows 11 x64).
> Configured with IIS and using .Net.
> When I open "http://localhost/mapguide/mapadmin/logproperties.php" (click the link after I have logged in to MapGuide Site Administrator) and try to uncheck "logging enabled" for Admin.log. I click on the Save button, and then i get this:
> [cid:fd712dc9-56f8-4e75-b371-bbcf3c2cdde3]
> I must edit serverconfig.ini with an editor to change the value, and then restart the service.
> Med vänlig hälsning
> Dan Nilsson
> Projektledare
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230407/5c547f78/attachment.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230407/5c547f78/attachment.obj>
