[mapguide-users] Unable to install MGOS 4 Beta 1
David Bowen dbowenrci at gmail.com
Mon Dec 18 06:30:49 PST 2023
Thanks Jackie. I was able to install it using the command line interface.
On Mon, Dec 18, 2023 at 6:29 AM Jackie Ng via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi David,
> As others have said, the general way to get around SmartScreen for freshly
> downloaded files is to right-click for file properties and unblock the file.
> But if this option is not available to you, you could try for a
> command-line based unlock solution:
> https://stackoverflow.com/questions/23048412/missing-unblock-button-under-properties
> If that fails and your computer is locked down by IT, perhaps it's some
> particular Group Policy in effect that is preventing you from being able to
> unblock this file.I can't tell you which Group Policy in particular this
> is, but you might ask your IT dept about this and see if they could relax
> such restrictions if that's the case.
> Failing that, then your only recourse is to try the InstantSetup bundle,
> which although it too is also an .exe file, it is also a 7-zip
> self-extracting archive, so you can open this file with 7-zip and extract
> the files within for a manual installation.
> - Jackie
> You wrote:
> I'm attempting to install MGOS 4 Beta 1 on a Windows 2022 server but am
> getting the following error:
> Microsoft Defender SmartScreen prevented an unrecognized app from starting.
> Running this app might put your PC at risk.
> [image: image.png]
> Has anyone encountered this before and have a workaround?
> Thanks,
> David
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20231218/daba2f3b/attachment.htm>
