[mapguide-users] Define map and layer to map in react-layout
H A hadissaalinia at gmail.com
Wed Dec 20 10:07:17 PST 2023
Good news! I finally got it worked, adding the lat/lon from the list to the
map and as a separate layer to the legend by using OpenLayers for defining
the vector and source and the following lines:
var layerMgr = viewer.getLayerManager();
 var layerInfo = layerMgr.addLayer(name, vectorLayer);
 viewer.dispatch(parent.MapGuide.Actions.Map.mapLayerAdded(viewer.getMapName(),
layerInfo));
Happy Holidays!
On Fri, Dec 15, 2023 at 7:26 PM Sympatico <pierre.cardinal at sympatico.ca>
wrote:
> Hi,
> Did you give a look at
> https://github.com/jumpinjackie/mapguide-react-layout-example ?
> Regards
> Pierre
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20231220/de5cd00d/attachment.htm>
