[mapguide-users] Blank map after importing packages
David Bowen
dbowenrci at gmail.com
Thu Dec 28 05:29:12 PST 2023
Hello Pierre,
The server is running Windows Server 2022 Standard. I"ve used Maestro to
check that the database connection is running properly and that the layers
aren't showing errors when I attempt to edit them.
David
On Wed, Dec 27, 2023 at 4:01 PM pierre.cardinal via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi David,
> What is your OS? Have you try Maestro with your new installation?
> Regards,
> Pierre
> -------- Message d'origine --------
> De : David Bowen via mapguide-users <mapguide-users at lists.osgeo.org>
> Date : 23-12-27 14 h 04 (GMT-05:00)
> À : MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Cc : David Bowen <dbowenrci at gmail.com>
> Objet : [mapguide-users] Blank map after importing packages
> I recently updated one of our servers to MGOS 4 Beta 1 and after I
> imported the package, using the Site Admin tool, the map no longer shows
> up. I’m able to see the login page, but once the credentials are passed, a
> blank page comes up. I’m not getting any errors in the console, Apache
> error log or PHP error log. I’ve tried importing different packages but
> nothing works.
> Has anyone else encountered this? If so, how did you resolve it?
> Thanks,
> David
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20231228/00673002/attachment.htm>
