[mapguide-users] MapGuide Fusion Error for Google Maps API
Jackie Ng
jumpinjackie at gmail.com
Thu Feb 9 04:28:01 PST 2023
If you want to use the mapguide-react-layout viewer over Fusion, I (as the
primary maintainer of the react viewer) am going to warn you up-front:
While we try to aim for maximum Fusion widget and Flexible Layout
compatibility in this viewer, Google Maps will not be supported by this
viewer, nor will I entertain any thoughts about integrating support for it
or any of the surrounding services (like Places, StreetView, etc, etc). The
Google Maps API is too much of a technological and legal minefield to
integrate with other map viewer libraries. There's a reason OpenLayers 3+
doesn't support it out of the box (eg:
https://github.com/openlayers/openlayers/issues/2205), and neither will we.
Frankly, that OpenLayers v2 (and thus Fusion by inference) had "supported"
Google Maps all this time is just plain luck. The only reason I haven't
fully yanked out this support in Fusion is that there might be backlash
from users and so my stance on the matter is purely "use at your own
risk/discretion".
My viewpoint on external map service integration is always going to be:
Please use Bing Maps or OpenStreetMap instead. They have much more
technologically and legally friendly integration stories.
- Jackie
You wrote:
We had a meeting with Gordon Luckett to discuss this issue and he provided
insight into what's causing it and a workaround solution. The Fusion
template relies on OpenLayers v2 and with Google Maps API v3.50, something
has changed that prevents it from working with OpenLayers v2, resulting in
Fusion errors.
As a workaround solution, if you remove both the GoogleScript tag, from the
XML, and live Google base maps in Maestro, the Fusion errors no longer
occur. You can replace the live Google base maps with the tiled versions,
which allows continuity for the end user.
It was also suggested to consider pivoting to using the React viewer
instead of Fusion, which is something I hope to look into in the future.
Hope this helps,
David
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230209/6a541118/attachment.htm>
