[mapguide-users] centering mult-line labels
Jackie Ng
jumpinjackie at gmail.com
Thu Feb 9 04:31:54 PST 2023
Good news: I've just integrated Layer Definition XML schema support to
support justification for feature labels for basic stylization. Full
details in this RFC that was just adopted:
https://trac.osgeo.org/mapguide/wiki/MapGuideRfc186
This support will appear in the upcoming MapGuide Open Source 4.0 Beta 1
release.
- Jackie
You wrote:
Are there any options for centering multi-line labels that I am
missing? I am trying to create a multi-line label for a polygon layer
that is centered horizontally in the feature. The only way that I
have been able to do this is to add a newline character in the label.
When I do this, the resulting label doesn't quite center horizontally
the way I want it to center. The entire label is technically centered
(based on the longest line), but each line of text is left justified.
Sometimes, this is desirable, but sometimes I want each line of the
label to be centered horizontally. Is there a way to do this? If
not, is this something that could make its way in to a future version?
Jon
This message may contain confidential, proprietary, or privileged
information. Confidentiality or privilege is not intended to be waived
or lost by erroneous transmission of this message. If you receive this
message in error, please notify the sender immediately by return email
and delete this message from your system. Disclosure, use,
distribution, or copying of a message or any of its attachments by
anyone other than the intended recipient is strictly prohibited.
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230209/0d681a44/attachment.htm>
