[mapguide-users] QuiqePlot Mapguide-react is Not working - mg.v.3.1.1.4601
Nimrod Cnaan nimcnaan at gmail.com
Mon Feb 13 10:07:03 PST 2023
Also If I set $protocol = "http://";
All Works fine.
SOLVED
‫בתאריך יום ו׳, 3 בפבר׳ 2023 ב-7:09 מאת ‪Jackie Ng‬‏ <‪
jumpinjackie at gmail.com‬‏>:‬
> I'll add to that previous thread with the following extra information:
>    - QuickPlot in mapguide-react-layout is not doing anything special. It
>    calls the same QuickPlot PHP backend that the regular Fusion widget does.
>    So you should detach this problem as being a mapguide-react-layout specific
>    problem. I am basically asserting here that your QuickPlot fusion widget
>    probably has the same issue.
>    - If you open PlotAsPDF.php and GeneratePicture.php in a text editor,
>    there are comments that are to the effect of "uncomment to to see ...."
>    uncommenting these regions will light up more debugging in these 2 scripts
>    and is something you want to do if you want to dig further into why
>    GeneratePicture.php is not returning an image. You only need to uncomment
>    sections in PlotAsPDF.php to get the correct GeneratePicture.php URL (which
>    is the important part you want to investigate)
>    - If you enable the extra debugging in PlotAsPDF.php and
>    GeneratePicture.php, then you most definitely want to set *display_errors
>    = On* in php.ini otherwise these errors might be suppressed.
> In summary, you need to get GeneratePicture.php to spit out the raw PHP
> error(s) instead of (no image). Following these bullet points should get
> you there.
> - Jackie
> You wrote:
> We have tried to pull every trick
> <https://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg24045.html>
>  (trik2 <https://trac.osgeo.org/mapguide/ticket/2778#no1>) in the book with
> no success.
> Regards
> Nimrod C.
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
בכבוד רב,
*נמרוד כנען**   |   *גיאומינד שירותי GIS  –  פיתוח,  ייעוץ  ושירותי ענן
ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
נא בקרו באתר החדש שלנו http://geomind.co.il
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230213/88dbbac7/attachment.htm>
