[mapguide-users] MapGuide Fusion Error for Google Maps API
Kyle Parker
kparker at aesi-consulting.com
Tue Jan 24 10:18:13 PST 2023
Hello all mapguide-users,
We are running MapGuide v3.1.1.9378 and have run into an issue using Google Maps API to bring in Google base maps. It looks like an issue with a deprecated call in the Maps API with the latest version. We have found that if you use the previous version of 3.49 in your Layout's GoogleScript instead of the current 3.51, the error no longer shows up. Version 3.49 will no longer be available after May 2023.
<GoogleScript>//maps.google.com/maps/api/js?key=KEYHERE&v=3.49&sensor=true</GoogleScript>
The base map appears to work fine after dismissing the pop-up.
Our webserver is running IIS, and we have added *.google.com to the Content Security Policy HTTP response header, but it had no effect. We would like to stick with MG v3.1.1 for now if possible.
I realize this is not a Google Maps help forum, however I was wondering if anyone else has run into this issue, and if you have found a way to either fix the erroneous 'width' call or prevent the error message from displaying. Thank you very much for your time and any comment you can provide. Thanks!
Kyle Parker
GDMS
Confidentiality Notice: The information contained in this message and any attachments may contain confidential or proprietary material and is intended solely for the use of the person or entity to which it is addressed. Any unauthorized review, use, disclosure or distribution of this communication is strictly prohibited. If you have received this communication in error, please immediately notify the sender by reply e-mail and destroy all copies of this communication and any attachments.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230124/bb4f643f/attachment.htm>
Type: image/jpg
Desc: JPEG
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230124/bb4f643f/attachment.jpg>
