[mapguide-users] make package mapadmin
Jackie Ng jumpinjackie at gmail.com
Wed Jun 14 05:01:42 PDT 2023
Root folder here means the folder in your site repository where you want to
package all resources within it. So for example, if your site repository is
laid out like this:
   - MyMap1
      - Data
      - Layers
      - Maps
      - Layouts
   - MyMap2
      - Data
      - Layers
      - Maps
      - Layouts
If you want to package everything under MyMap1, you would use either:
   - Library://MyMap1/
   - //MyMap1/
And if you load this package on a different MapGuide Server, it will
re-create this folder structure on that MG server as part of loading all
the packaged resources.
   - MyMap1
      - Data
      - Layers
      - Maps
      - Layouts
If you want to package everything in the site repository, you can use
Library:// or //
You can only package a single folder with the mapadmin, you cannot package
multiple different folders at the same time.
Hope that helps.
- Jackie
You wrote:
How do i make package on the mapadmin page? It quiet confuse about the
syntax to use
|* Folder name (e.g. Library://<root_folder>/<folder1>): |
root folder of what?
i tried to doLibrary://Packages/Library://Backup/Library://Library://<server
name>/packages/Library://<server name>/
still not working, can someone help me on this?
Thanks
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230614/be8dae82/attachment.htm>
