[mapguide-users] White tiles at z = 0
Gunter Becker
gunter.becker at csoinfo.de
Fri Mar 3 03:29:01 PST 2023
I opened a new ticket: https://trac.osgeo.org/mapguide/ticket/2863
Gunter
Von: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Im Auftrag von Gunter Becker
Gesendet: Freitag, 3. März 2023 11:50
An: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Betreff: Re: [mapguide-users] White tiles at z = 0
Additionally, I found that when you include a RasterLayerDefinition in the TileSetDefinition, the tiles are no longer white, but a mix of colors.
Seems like a bug to me
Von: mapguide-users <mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>> Im Auftrag von Gunter Becker
Gesendet: Freitag, 3. März 2023 10:42
An: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
Betreff: [mapguide-users] White tiles at z = 0
In our application I use a MapDefinition with an external TileSetDefinition of the type "Default Tile Provider". We access this MapDefinition in our OpenLayers frontend from a map that is set to a local coordinate system (EPSG:25832). In the TileSetDefinition I have defined this CoordinateSystem and the scales in which I want the tiles to be created:
500000,250000,100000,50000,25000,10000,5000,2500,1000,500,250,100
With MapGuide version 3.1.2 everything works as expected.
However, it turned out that in the latest beta version of MapGuide 4 at a scale of 1:100 (TileCoordinate z = 0) only white tiles are created.
All the other Scales are correct.
I tested this by using the MapGuide package that I created under 3.1.2 and then loading it into MapGuide 4 Preview 4. So, it is exactly the same configuration.
Maybe someone else has an idea what I could try. Otherwise I would open a ticket.
Thanks,
Gunter
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230303/330801a2/attachment.htm>
