[mapguide-users] SQL Server connection with windows authentication
Gordon Luckett gordon.luckett at arrowgeomatics.com
Fri Mar 17 07:54:25 PDT 2023
If mapguide server is logged into SQL Server as a user that have windows
authentication, you should be able to do this.
For example, make a network user called mapguide_server_user, and log into
MapGuide Services as that user and grant that user access to SQL Server,
you can use Windows Authentication.
On Fri, Mar 17, 2023 at 10:46 AM Gunter Becker <gunter.becker at csoinfo.de>
wrote:
> Hi,
> is it possible to connect to a SQL Server database using integrated
> security (windows authentication) in FDO Provider? If so, how can I do that
> in Maestro, for example? So far I've only done this with SQL authentication.
> Thanks, Gunter
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230317/a02e265a/attachment.htm>
