[mapguide-users] DB XML Error and Packages
David Bowen dbowenrci at gmail.com
Fri Mar 31 07:30:20 PDT 2023
I'm encountering an issue when trying to load packages using Maestro. For
example, I'm attempting to load the package created from our Production
environment into the Development environment and I get the following errors:
The remote server returned an error: (559) MgDbXmlException.:
An exception occurred in DB XML component.
Error: DB_BUFFER_SMALL: User memory too small for return value
- MgResourceServiceHandler.ProcessOperation() line 80 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpApplyResourcePackage.Execute() line 96 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\OpApplyResourcePackage.cpp
- MgServerResourceService.ApplyResourcePackage() line 815 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgLibraryRepositoryManager.ApplyResourcePackage() line 148 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\LibraryRepositoryManager.cpp
- MgLibraryRepositoryManager.LoadResourcePackage() line 183 file
- MgResourcePackageLoader.Start() line 145 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourcePackageLoader.cpp
- MgResourcePackageLoader.PerformOperation() line 223 file
- MgResourcePackageLoader.SetResource() line 303 file
- MgRepositoryManager.SetResource() line 559 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\RepositoryManager.cpp
- MgRepositoryManager.AddResource() line 532 file
- MgResourceContentManager.AddResource() line 178 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceContentManager.PutDocument() line 619 file
- MgResourceDefinitionManager.PutDocument
(MgLibraryResourceContents.dbxml)() line 545 file
c:\working\build_area\mapguide\3.1.2\x64\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
System.Exception: The remote server returned an error: (559)
MgDbXmlException.:
 ---> System.Net.WebException: The remote server returned an error: (559)
MgDbXmlException.
   at System.Net.HttpWebRequest.GetResponse()
   at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.UploadPackage(String
filename, StreamCopyProgressDelegate callback) in
C:\projects\mapguide-maestro\OSGeo.MapGuide.MaestroAPI\Http\HttpServerConnection.cs:line
1511
   --- End of inner exception stack trace ---
1525
   at Maestro.Packaging.PackageBuilder.UploadPackage(String sourceFile) in
C:\projects\mapguide-maestro\Maestro.Packaging\PackageBuilder.cs:line 183
   at
Maestro.Packaging.PackageProgress.<>c__DisplayClass10_0.<UploadPackage>b__0()
in C:\projects\mapguide-maestro\Maestro.Packaging\PackageProgress.cs:line
175
   at Maestro.Packaging.PackageProgress.backgroundWorker_DoWork(Object
sender, DoWorkEventArgs e) in
C:\projects\mapguide-maestro\Maestro.Packaging\PackageProgress.cs:line 395
   at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
   at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object
argument)
Based on previous threads, I've attempted to increase the following
parameters in the serverconfig.ini file but have had no success.
#SessionDBXMLPageSize = 0.5
SessionDBXMLPageSize = 1.0
#SessionDBPageSize = 2
SessionDBPageSize = 4
#SessionLogBufferSize = 1
SessionLogBufferSize = 5
#LibraryLogBufferSize = 12
LibraryLogBufferSize = 24
#DBXMLPageSize = 32
DBXMLPageSize = 64
#DBPageSize = 32
DBPageSize = 64
Has anyone else encountered this issue and have figured out a solution?
Thanks,
David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20230331/3f5dda95/attachment.htm>
