[mapguide-users] MapGuide Open Source 4.0 RC1 plans and some remarks on MVT tiles
Gordon Luckett gordon.luckett at arrowgeomatics.com
Fri Oct 27 02:21:30 PDT 2023
HI Jackie,
from my perspective, I never use the MVT.  I would not be disappointed if
you dropped it from the next build (at least for now).
On Fri, Oct 27, 2023 at 10:16 AM Jackie Ng via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi All,
> I am currently putting the finishing touches on a new mapguide-rest
> release that will be compatible with both 3.1.2 and current 4.0 Beta, thus
> fully validating the new PHP binding work (if mapguide-rest can work with
> these new PHP bindings, then there is no real reason your PHP MapGuide
> application should not work as well!)
> Which means that after the new release of mapguide-rest I can divert my
> full attention back onto MapGuide proper and work towards the RC1 release.
> The main goals for the RC1 release will be:
>    - Getting the supplemental stories around the new API binding work
>    ready, such as:
>       - Getting the .net binding packages onto nuget
>       - Per-language API documentation instead of using doxygen with an
>       umbrella static gateway site to point to all 3.
>    - Getting mg-desktop working under the new API bindings
>    - Updating Apache/PHP/Tomcat again to whatever the current version is
>    - Fixing the PostGIS problem reported on this list and on trac (
>    https://trac.osgeo.org/mapguide/ticket/2874). I'm still looking for
>    solid reproduction steps against some PostGIS dataset that I can replicate
>    locally. That will help drastically reduce turnaround time on a
>    solution/fix.
>    - Addressing any other minor MapGuide/FDO issues that can be addressed
>    in this timeframe.
> But one particular item I want to talk about (and too important to fit
> into a single bullet point) is around the new Mapbox Vector Tile (MVT)
> support. I have personally been disappointed with the implementation I
> added because outside of the Sheboygan dataset, it is not producing the MVT
> tiles I am expecting, with a whole random assortment of geometry and
> rendering artifacts in my OpenLayers examples.
> I am strongly considering pulling this feature out of the codebase because
> I do not have the confidence to actually fix these issues because the
> implementation was predicated on "I trust this library of code to
> write/encode MVT tiles to spec and so I will integrate said code into the
> MG rendering/stylization pipeline".
> That "library of code" is the MVT tile encoder from the GDAL/OGR MVT
> driver and whatever "trust" I had in this code was somewhat shook when I
> used ogr2ogr directly to produce these MVT tiles and even then, the MVT
> tiles would not display correctly in my OpenLayers examples. Now
> admittedly, I was using an older version of the tile encoder and ogr2ogr
> (v2.4.4), so the implementation may have been immature. But a starting
> position of "not fully working" doesn't give me hope.
> This has been my experience with MVT tile support. How has your experience
> been with this new feature? Does it actually produce MVT tiles as you
> expect?
> Please try to convince me that this is a feature worth keeping. Be honest
> in your appraisal of the current implementation. If MVT support isn't fully
> working for you, then that is a situation that is not likely to improve so
> we're better off just pulling the feature out and just relying on
> external/dedicated MVT encoding tools on your data to do the job better.
> - Jackie
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20231027/62174287/attachment.htm>
