[mapguide-users] MapGuide 4.0 Beta 1
Patrik Johansson
mapguide at morkl.se
Tue Apr 30 07:42:44 PDT 2024
Hi again,
I don't know how this slipped through during my previous round of tests,
but there's a third get_magic_quotes_gpc in
fusion\widgets\Search\Search.php that breaks the Search widget.
The attached patch fixes that one as well.
Best regards,
Patrik Johansson
On Fri, Apr 7, 2023 at 12:25 PM Patrik Johansson <mapguide at morkl.se> wrote:
> Hi,
> Two of the Fusion php scripts also fail because of get_magic_quotes_gpc:
> * Web\www\fusion\layers\MapGuide\php\GetSelectionProperties.php
> * Web\www\fusion\layers\MapGuide\php\SaveSelection.php
> The attached patch removes the call from both of them.
> Best regards,
> Patrik Johansson
> On Thu, Apr 6, 2023 at 5:15 PM Jackie Ng <jumpinjackie at gmail.com> wrote:
>> Hi Dan,
>> Thanks for the heads up.
>> A fixed version of serverdatafunctions.php is available in the
>> post-release section of the 4.0 Beta 1 release notes.
>> https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Beta1/Notes#Post-releasepatches
>> - Jackie
>> You wrote:
>> Hi!
>> I have just installed MapGuide OpenSource on my virtual machine (Windows 11 x64).
>> Configured with IIS and using .Net.
>> When I open "http://localhost/mapguide/mapadmin/logproperties.php" (click the link after I have logged in to MapGuide Site Administrator) and try to uncheck "logging enabled" for Admin.log. I click on the Save button, and then i get this:
>> [cid:fd712dc9-56f8-4e75-b371-bbcf3c2cdde3]
>> I must edit serverconfig.ini with an editor to change the value, and then restart the service.
>> Med vänlig hälsning
>> Dan Nilsson
>> Projektledare
>> *Please Note: I no longer create new posts or post replies to any OSGeo
>> mailing list through nabble. As a result, you most likely won't see this
>> message appear on nabble's view of any OSGeo mailing list and may only see
>> this message through mailing list archives or depending on your mailing
>> list subscription settings, through daily message digests or automated
>> notifications from the mailing lists.*
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240430/08b9a266/attachment.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240430/08b9a266/attachment.obj>
