[mapguide-users] MapGuide-React-Viewer - localize true/false value
Jackie Ng jumpinjackie at gmail.com
Tue Aug 13 07:06:23 PDT 2024
If you're asking this question, then probably not.
If you require an immediate solution, search for this string in the code
and introduce a new localizable string key for it and provide the english
baseline text in en.json and then translated versions in their respective
language string json bundle file.
Then do a new webpack production build with these changes and deploy the
new viewer production bundle and its updated string json files.
- Jackie
You wrote:
Is there a way to localize  the *Selection boolean field value from
true/false to yes/no value ?*
nimrod
muni.geomind.co.il
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240814/b6953330/attachment.htm>
