[mapguide-users] Unable to save MapGuide Site Admin tool
David Bowen
dbowenrci at gmail.com
Thu Jan 11 06:55:59 PST 2024
Thanks Pierre. That solved the problem.
On Wed, Jan 10, 2024 at 3:02 PM <pierre.cardinal at sympatico.ca> wrote:
> Hi David,
> To fix the problem “definitely”
> Remove or comment the two following lines in the file
> ..\Web\www\mapadmin\serverdatafunctions.php
> function CleanUpMagicQuotes( &$path )
> // if ( get_magic_quotes_gpc() )
> // $path = str_replace('\\\\', '\\', $path );
> The function get_magic_quote_gpc() is deprecated.
> Restart your Apache server
> Regards,
> Pierre
> *De :* mapguide-users <mapguide-users-bounces at lists.osgeo.org> *De la
> part de* David Bowen via mapguide-users
> *Envoyé :* 10 janvier 2024 09:30
> *À :* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Cc :* David Bowen <dbowenrci at gmail.com>
> *Objet :* [mapguide-users] Unable to save MapGuide Site Admin tool
> I'm attempting to update settings in the Site Administrator tool but when
> I click on Save, a blank page is returned. When I click on the go back
> button, none of the updated settings are shown.
> Has anyone encountered this? I know you can update the serverconfig.ini
> file but I'm trying to update how often the logs are archived and there
> doesn't appear to be an option for it in the serverconfig.ini file.
> Thanks,
> David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240111/8269f8b7/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240111/8269f8b7/attachment.png>
