[mapguide-users] Authentification doesn't work
pierre.cardinal at sympatico.ca
Wed Jan 17 05:07:43 PST 2024
Hi François,
To start manually your MapGuide server, the exact command is "<MapGuide installation directory>/Server/bin/mgserver.exe run"
The parameter "run" was missing in my previous email. Sorry.
Pierre
-----Message d'origine-----
De : frdl at free.fr <frdl at free.fr>
Envoyé : 17 janvier 2024 02:41
À : pierre.cardinal <pierre.cardinal at sympatico.ca>
Cc : MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Objet : Re: [mapguide-users] Authentification doesn't work
I restarted the service and I still got the same error message when trying to login in mapadmin. When trying to use the mapagent page, the page stays blank after the login popup, so I do think that, as you say, Mapguide server is not properly running, but I have no idea why.
Thanks,
Francois
----- Mail original -----
De: "pierre.cardinal" <pierre.cardinal at sympatico.ca>
À: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Cc: frdl at free.fr
Envoyé: Mardi 16 Janvier 2024 16:03:14
Objet: RE: [mapguide-users] Authentification doesn't work
Hi François,
This problem is in general caused by the fact that your MapGuide server is not running. Check your services for MapGuide server or try to start you server with the following command ".. /server/bin/mgserver.exe" in the directory where you installed the MapGuide application.
Salutations,
Pierre
Envoyé de mon appareil Samsung de Bell via le réseau le plus vaste au pays.
-------- Message d'origine --------
De : Francois Regnard via mapguide-users <mapguide-users at lists.osgeo.org> Date : 24-01-16 02 h 13 (GMT-05:00) À : mapguide-users at lists.osgeo.org Cc : frdl at free.fr Objet : [mapguide-users] Authentification doesn't work
I recently tried to install mapguide 4.0.0.1 on a Professionnal Windows 10 for my company. Up until then, we used a linux server for that, but I had to fetch the data on the windows server for our users to have the same experience as they're used to. However, logging in, even as Administrator, doesn't work. It gives back an error "Authentification failed. Please enter a valid username and password."
Just to be sure, I uninstalled everything, rebooted, reinstalled Mapguide leaving every default option (ip adress, port, packages...), and I still get the same authentication error. Could that be related to ports or something like that ?
Thanks,
Francois
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
