[mapguide-users] MGOS 4.0 and PostgreSQL
pierre.cardinal at sympatico.ca
Sat Jan 20 14:25:09 PST 2024
With
Postgis 3.2,
PostgreSQl 14,
MgServer 4.0.0.10048
Apache or IIS
libpq.dll 11.4
Windows 10
Database server, Web server and MapGuide server all on the same machine
I am never seeing this error and I am displaying POINTS and POLYGONS from
PostGIS.
Regards,
Pierre
-----Message d'origine-----
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de
svlad via mapguide-users
Envoyé : 17 janvier 2024 07:58
À : mapguide-users at lists.osgeo.org
Cc : svlad.cjelli42 at web.de
Objet : Re: [mapguide-users] MGOS 4.0 and PostgreSQL
hi,
I have tested the PostgreSQL/PostGIS Provider 4.2 with PostgreSql 15,
Postgis 3.4.
After some zoom or pan actions the following error occurs:
Objects disappear and appear randomly.
The MapGuide server reports the following error:
Error: Failed to stylize layer: LAYER1
An exception occurred in FDO component.
Error occurred in Feature Source
(Library://Data/POSTGRESQL.FeatureSource): Class 'public:qry_table' not
found (Cause: , Root Cause: Class 'public:qry_table' not found )
StackTrace:
- MgMappingUtil.StylizeLayers() line 918 file
C:\working\build_area\mapguide\4.0.0\x64\MgDev\Server\src\Services\Mapping\M
appingUtil.cpp
Once this error has occurred, an error also occurs in Maestro when trying to
select the data source:
Failed to enumerate data stores...
If you reenter the password, it works again.
The error was also already requested in May 2021 by woody2 with MG 3.1.
I have tested with different MG versions (3.1.2, 4.0 Beta 1), different
libpq.dll (11, 12, 15), Fusion Viewer and React Layout.
The error is always the same.
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
