[mapguide-users] IronPython - automate Maestro
Jackie Ng jumpinjackie at gmail.com
Wed Jul 24 07:13:04 PDT 2024
If you focus at this part of the error: NoneType has no attribute 'AddRule'
Then IronPython is really complaining about the expression:
vectorScaleRange.PointStyle
Which is just another way of saying that the vectorScaleRange has no
actual point style because it is null (on in Python terminology: None)
ie. You are adding to a layer without a point style set on the given scale
range
How can you rectify this? If this is the correct layer definition you
intend to add a point rule to, then you should assign a point style if
vectorScaleRange.PointStyle is None.
Where can you create a new point style? From the same place where you're
creating point rules: The layer definition object itself.
- Jackie
You wrote:
Hello Jackie,
I ran into a problem trying your code.
This Line does not seem to work:
vectorScaleRange.PointStyle.AddRule(pointRule)
Error when running the code:
[cid:image001.png at 01DADDBD.2CF4D050
<https://lists.osgeo.org/mailman/listinfo/mapguide-users>]
I ran a dir() on the vectorScaleRange variable and it shows no AddRule.
I will take a better look at the API documentation
[cid:image002.png at 01DADDBD.2CF4D050
Met vriendelijke groet,
GISkit BV
Bart Oostdam
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240725/d1d0858e/attachment.htm>
