[mapguide-users] AutoDesk Oracle Driver and NLS Variables
David Bowen
dbowenrci at gmail.com
Fri Mar 8 06:08:31 PST 2024
We're testing using the AutoDesk Oracle driver in MGOS Beta 1, running on
Apache on Windows Server 2022 Standard, and are encountering an issue when
we select an object to query against the database (Oracle 19).
Instead of returning results, that are being returned when using the Oracle
SLKING driver, we're getting an error message (image 1).
Image 1:
[image: image.png]
The relevant section of code is as follows:
function _setEnvironment() {
//// Set Oracle NLS variables
$NLS_ENV = "ALTER SESSION SET NLS_NUMERIC_CHARACTERS='.,'";
$set = $this->db_app->simple_query( $NLS_ENV );
$NLS_ENV = "ALTER SESSION SET NLS_DATE_FORMAT='YYYY-MM-DD'";
It fails when attempting to run the first simple_query, and I presume it
will fail when attempting to run the second simple_query. Has anyone
encountered this or are using the AutoDesk Oracle driver where the NLS
variables are being set?
Thanks,
David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240308/4c367514/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240308/4c367514/attachment.png>
