[mapguide-users] MapGuide 4.0 Beta 2
David Bowen
dbowenrci at gmail.com
Wed Mar 27 04:33:13 PDT 2024
Hi Jackie,
Thanks for the update. We really appreciate all of the hard work that
you've put into MapGuide and your patience with all of the questions.
On Fri, Mar 22, 2024 at 5:51 PM Martyn Andresen via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi Jackie: I would like to take this opportunity to thank you for all of
> the work you have done. It is very much appreciated and we continue to be
> excited to see MapGuide evolve.
> On Tue, Mar 19, 2024 at 10:55 AM Jackie Ng via mapguide-users <
>> Hi David,
>> I must apologize for these repeated delays and failed promises. The
>> reality of the situation is that my day job has absolutely drained any
>> energy I have remaining to tackle MapGuide and FDO dev, which is why these
>> time frames keep slipping.
>> Rather than throw out another date that I'll probably miss, I'll just say
>> that I'll try to jump-start some dev activity later this month and if I get
>> some momentum, I'll follow up with a revised time frame.
>> - Jackie
>> You wrote:
>> Hi Jackie,
>> Is there any update on when MapGuide 4.0 Beta 2 will be released?
>> Thanks,
>> David
>> mapguide-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20240327/c815b08c/attachment.htm>
