[mapguide-users] MGOS 4 Memory Leak
Jackie Ng jumpinjackie at gmail.com
Thu Oct 10 14:38:22 PDT 2024
Are your King Oracle feature sources using the KingFdoClass metadata table
feature for cleaner class names?
If so, a leak was identified and plugged on that front.
https://trac.osgeo.org/fdo/changeset/8279
This was leaking on every DescribeSchema request where the connection was
configured with the KingFdoClass metadata table. The more rows in that
table, the more leaks per request.
- Jackie
You wrote:
Forgot to mention that once the memory starts to be consumed it's a run
away event, meaning that it doesn't seem to stop until the services fail
and have to be restarted.
Thanks,
David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20241011/a7f0a13b/attachment.htm>
