[mapguide-users] MGOS 4 Memory Leak
Jackie Ng
jumpinjackie at gmail.com
Wed Oct 23 02:40:38 PDT 2024
(Copy of reply for the mailing list)
The only tests are new provider test cases I've added exercising the
provider under API usage scenarios of a regular FDO client application.
This is my only avenue for finding possible leaks given the absence of
solid and reproducible data and scenarios where leaks are definitely
happening.
I'm still fleshing out this provider test suite in the hopes of finding
more leaks, but if I don't find any more after fleshing out this suite
there's not much else I can do.
- Jackie
On Wed, 23 Oct 2024 at 06:16, David Bowen <dbowenrci at gmail.com> wrote:
> Hi Jackie,
> As far as we can tell, we're not using the KingFdoClass metadata table.
> Are there other memory leak tests being conducted?
> David
> On Thu, Oct 10, 2024 at 5:51 PM Jackie Ng via mapguide-users <
> mapguide-users at lists.osgeo.org> wrote:
>> Are your King Oracle feature sources using the KingFdoClass metadata
>> table feature for cleaner class names?
>> If so, a leak was identified and plugged on that front.
>> https://trac.osgeo.org/fdo/changeset/8279
>> This was leaking on every DescribeSchema request where the connection was
>> configured with the KingFdoClass metadata table. The more rows in that
>> table, the more leaks per request.
>> - Jackie
>> You wrote:
>> Forgot to mention that once the memory starts to be consumed it's a run
>> away event, meaning that it doesn't seem to stop until the services fail
>> and have to be restarted.
>> Thanks,
>> David
>> mapguide-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
http://themapguyde.blogspot.com
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20241023/6b1e9f04/attachment.htm>
